Old 09-03-2023, 10:56 AM
L79v L79v is offline
Cobra Make, Engine: Contemporary, 427 SO
Thank you, I will check float levels first. Contemporary Cobra, engine is 427 with 428 crank stroked to 4.125". Reed solid lifter cam, BBM heads, 11.7 compression, Mallory billet distributor. Quick Fuel carb, 830 Super Street, 830cfm, dual inlet, mechanical secondaries. Primary main jet 78 secondary 84. I have a lot of information from the original owner, and from the engine builder I used. I can probably find the answer to any questions. I appreciate your advice, Gene
