Old 09-18-2023, 01:12 PM
FlyingGumby's Avatar
FlyingGumby FlyingGumby is offline
Cobra Make, Engine: BDR #870 Salsa Red w/White stripes Roushcharged 4.6L 3V
Default Backdraft outer tie rod ends
Needed an outer tie rod end for a 2010 BDR. Contacted a few vendors and googled. Daniel Fischetti from Dessert Valley Motorsports came through with part ES3401RL.
Dimensions are very close… a little less dip and the post is ~.25” taller. Used safety wire on the castle nut as the cotter pin was tight. Aligned perfectly. Steering is tight.
Found Daniel on FB/Backdraft Owners Group. Very responsive. Shared his knowledge openly on this and other topics. Thanks Daniel.
