Old 09-19-2023, 09:16 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
If the radiator is a Fluidyne it is readily available from Jegs (where I got mine).
If it is Fluidyne it's a single bolt with rubber grommet on the top and a couple of mounts on the bottom. Mine slipped right out.
The radiator "electrically floats" and this causes the leaks you notice. Do two things.
First, attach a ground strap somewhere.
Second, the unit I got from Jegs included a sacrificial anode (much like a water heater). Depending on the plumbing if there is a spare hole screw it in.
Tony
CSX4005LA
