Thread: Battery
Old 10-04-2023, 08:20 AM
Randy Rosenberg Randy Rosenberg is offline
Cobra Make, Engine: SPF #1019
Originally Posted by Davidless View Post
So a 24f is what is needed to fit in the small SF compartment with top posts?
David
Well.... During my quest to fit the largest possible battery, I learned that not all batteries are the same dimensions, even though they have the same "size number". IE: Not all 24F batteries have the same external dimensions - they are similar, but not the same.
To get the Interstate MTX-24F to fit, not only did I have to trim the sides (hence removing the factory handle), but I had to trim the underside of the battery cover, because this 24F was taller. I used a 1" wide nylon strap wrapped around the bottom and up the sides to work as a handle to lower the battery into the compartment. I left the strap there for the time that I'll have to pull it out.
I needed a longer negative battery cable that I ordered from here: https://www.batterycablesusa.com/
Hope this helps,
Randy...
