		Here's my guess.  It is common for the ignition switch to remove power from everything except the ignition and starter when the switch is placed in the START position.  That could explain why the voltmeter is going to zero when you turn the key.  My guess is that the no crank problem is due to a safety circuit associated with the brake or clutch.  You may need to temporarily bypass any switches to determine which circuit is the problem.
				Tommy
Previously owned EM Cobra
