I took my windshield out when I replaced the dash. The windshield is straight across and comes out easily. You could, potentially, modify the ear or make a small bracket to do what you are proposing. There is not a lot of room under there. Just be warned that the windshield will easily break if put under torque or tension when re-installed. You could, potentially, run into a sealing problem on the bottom. Good Luck.
Fred
Originally Posted by coach36
Hey, I'd like to give my windshield a little bit more rake. A more laid back look. Anyone done that? What needs to be done?
