Old 10-13-2023, 08:53 AM
eschaider's Avatar
You did not indicate if you were building with an IRS or a stick axle. It sounds like you are using a stick axle rear suspension. If that is true, then any of the 8.8 axle housings will provide you with a good starting point. Determine the width you want to use and then either trim the existing axle tubes if they are too long or remove them and install longer tubes if they are too short.
Once you have the tube selection behind you, decide the ends you want to use based on the brakes you intend to use. Weld the appropriate ends on and you are done.
