Old 11-03-2023, 08:55 AM
stallion112's Avatar
stallion112 stallion112 is offline
Cobra Make, Engine: Kellison Stallion, 429 SCJ,
Thanks for the feedback guys, much appreciated.
Bill, I like the way yours is mounted in front of the axle. Originally, I was planning on mounting the pump behind the axle and to the front side of the frame that wraps around the trunk (this is where the ~30 degree angle came from).
I too like the fact that a rebuild kit is available for the pump, plus the fact that you don't need a return line. I was planning on having to run a return line back to the tank but believe it or not I've never had any problems with vapor lock so I should be good to go with the pusher pump.
Stallion112
