Old 11-06-2023, 04:25 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Ok, mine has a 1” wide plate the length of the battery box bonded on the outside bottom of the battery box. I would guess two pieces of round rod are tacked to the 1” plate and project up thru the fiberglass and into the battery box. They would be threaded at the top for the knurl nuts to secure the cover. Send me an email message and I’ll take a photograph for you. Appears easy enough to fabricate something. What is your chassis number? Odd that the bonding would fail unless mounting bracket was removed by previous owner to fit off spec battery?
Blas
SPFWiringDiagrams@Comcast.net
