Old 11-06-2023, 05:18 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Phil
Picture of my linkage. The bellcrank works thru the full range, having about 45 degrees on one side of center and the full open position about the same on the other side.
The rear link length will depend on where you place the crossshaft and really isn't critical.
The levers on the cross shaft are about 2-1/2" pivot to ball and again, they work equal amounts either side of 90degrees.
The lever on the foot pedal is about 3-1/8" from ball center to pivot shaft center. The footpedal is a replica of the originals
Paul
www.65shlb.com
www.prdcrrct.com
