Thread: Era2158
  #40 (permalink)
Old 05-05-2024, 10:20 AM
6TNCRZY 6TNCRZY is offline
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
Thought I would update a couple or the changes I made over the winter. I had installed Sniper Stealth on the car when I built it and wanted a fuel pressure gauge. The original FIAs had a pressure gauge where ERA put the fuel level gauge. On the FIA if you remove the gas cap you can see the fuel level so the level gauge is really not needed. I took a SW oil pressure gauge, carefully removed the bezel, removed the "oil" from the face with brake cleaner, carefully reassembled and installed where the level gauge was in the dash. The gauge looks very similar to the 0 to 10lb gauge in the original cars.
