Old 05-28-2024, 08:37 AM
C5GTO's Avatar
C5GTO C5GTO is offline
Originally Posted by eschaider View Post
Unless your engine failure was caused by an overheating problem, it was a tune problem. You will need to get your EFI retuned for your new engine, or it will suffer a similar but more extreme version of the failure you are currently repairing because of the increased power levels.
It wasn't a coolant system overheat problem as the coolant temps at the gauge sensor didn't exceed 195 degrees prior to the failure. It might have been a localized overheat issue around that cylinder but I have no way of knowing that.
It could be a tune issue as the EFI system is a 30 year old EEC IV setup. The EFI was dyno tuned about 10 years ago but that was done much closer to sea level. The engine failure occurred at about 7,000 ft elevation. Yes, the ECU should have adjusted for the elevation change but you never know.
I am looking into a new EFI for this engine at this point. Another reason is driving this but I'm also concerned that the existing 30 year old EFI tech is a shaky foundation to build on and my trust level with it is low.
Thanks,
Joel Heinke (early 90's CRL Cobra)
