Originally Posted by Daytona Dek
Sorry if this is a bit of a numpty question but my Daytona fitted with a 302 and Edelbrock Thunder 1805 carb is difficult to start when it’s still hot. I think it’s due to fuel evaporation not heat soak on the starter. It will start eventually but after an embarrassing amount of churning. Is there a technique I can adopt to improve things like opening the throttle wide but don’t know the exact details?
If you think fuel evaporation due to heat soak is the issue,
lifting the hood after shutdown helps. Of course in a Daytona
that's also a PITA.
Check that fuel lines are not making contact with the engine.
Insulate fuel lines near engine.
Install a heat shield kit around carb.
If all else fails you can also try...........
Using non-ethanol fuel mixed with unleaded racing gas.
Race gas has a lower RVP (Reid Vapor Pressure) rating
for the specific purpose of better starting characteristics
of heat soaked engines. Downside is you may need to
adjust/tune for it. Sunoco 260 GTX is non-oxygenated
unleaded 98 octane. 91 octane non-ethanol mixed
50/50 with 260 GTX is confirmed to work well for hot
starts and reduced vapor lock tendencies.
