You can go only go so far bench-setting a carb for a performance engine that has an intake manifold that doesn't even sit level. Your floats are never going to be right until you set them when they're on the engine. That's not a big deal. You used to be able to just pull into an Esso and they'd set them for you while you chatted with Mabel behind the counter....
