Old 06-11-2024, 06:40 PM
Quentin Z's Avatar
Quentin Z Quentin Z is offline
Cobra Make, Engine: Backdraft #272, 351W
Yeah, I posted a link to your FB post. Looks like the correct one. I can't believe they still have them (I ordered a couple myself). If you get in there and find that you need inner tie rods too, they are MOOG EV239, and the Tie Rod Boots are Moog K150272. IIRC, the inners are a little longer than stock, so you'll have to measure a bit. Oh, and you'll need the Maddox inner tie rod removal tool from Harbour Freight:
https://www.harborfreight.com/inner-...r+tie+rod+tool
Note: For the outer ones you won't be able to use the kottar pin; you'll have to use safety wire. I don't think the lock nuts will work, but this is all from my feeble memory. You'll figure it out once you are in there...
