Originally Posted by Gaz64
Impressive, but I would get rid of the venturi and auxiliary venturi, since they are now a restriction for airflow. I'd make up a blocked off main jet and air corrector for the emulsion stack.
Then all airflow will only be via the stack. At the moment you have a stock 37mm choke, where it could be a straight barrel down to 48mm.
Gary
Hi Gary,
I want to keep the top venturi's for the classic look. The 37mm chokes have already been removed though.
The old fuelling system is all internally blocked off.
