Do you know what the case you are using originally came out of?
I did this complete changeover to a Dana 44 set-up on mine and used a Richmond Power Grip. I had no problems at all. The Dana 44 has a break point of 3.7. Higher than 3.7 requires a different carrier. Salisbury had a break at 3.54.
Here are the bearing numbers I used:
Carrier Bearing: 25590
Carrier Race: 25523
