Lorenzo, sorry for the delay in getting back to you! As you mentioned in your post the correct suffix for all Contemporary is CCX (C ontemporary C lassic X port) . The number you supplied on your post doesn't resemble anything that I have ever seen produced hear in the states by Contemporary. On top of the Passengers Footbox you should see an aluminum plate that states that the vehicle was manufactured by Contemporary Classic Motor Car Company in Mt. Vernon, NY. "It is a Ferderal offense to remove this tag" Also the Serial # CCX 3-3_ _ _ or
CCX- 3 _ _ _ should appear on this tag. This very same serial Number is stamped into the 4" main rail just below the Front upper A arm suspension. Hope this helps you. If you can send me detailed photos of these serial numbers as well as the underside of the cobra I will be better able to say yes or no to it's authenticity!
Bill Connelly
Upstate Super Replicars, Inc.
www.daytona-coupe.com
427cobra@compuserve.com
