Ed, this problem can be attributed to 2 possible problems. The 1st of which is the improper location of Watts Chassis mount brackets. I have a gig that can locate these for you. It may entail the removal and rewelding of the brackets that you have mounted. The 2nd possiblity is the improper adjustment of the actual linkage arms themselves. The object in adjusting the linkage arms is to have both very near equal length. Start at about 9 1/2" c to c of heim for both the front an the rear. When you install both of these linkage arms make sure all the coil overs are removed and you have your ride height gauge installed. Refer to your Contempoary manual on how to fabricate a ride height gauge. Once the ride height gauge is in place and you have adjusted / installed the 2 equal length linkage arms; remove the ride height gauge and check for free movement of travel in the up and down plane. You should not have any binding at the bellcrank what so ever. If you do see binding you will need to reinstall your ride height gauge and re-adjust your linkage arms. NOTE: The top arm of the bellcrank when adjusted properly will be angled forward at about 15 to 20 degrees.
If you have followed all of the above steps and are still breaking these shoulder bolts you may want to ugrade to our Billet Aluminum Watts link hub carriers which have a beefier pivot bracket!
Bill Connelly
Upstate Super Replicars, Inc.
www.daytona-coupe.com
427cobra@compuserve.com
