Old 07-01-2002, 11:40 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Hi guys - the following is only pertinent to Jag rear ends, but I guess it is generic enough to be worth posting.
I have a friend here in the UK who drag races. He puts 750Hp + through a std jag rear end. After 4 passes, he measures the twist or "set" in those solid halfshafts - after 1/2" of twist he throws them away and fits some new (secondhand) ones.
When building my own car, I asked a driveshaft specialist for advice, we decided to uprate the half shafts/yokes/UJ's on my rear end. Mainly because those half shafts are the only thing keeping the rear wheels in position, and I wanted it to last for more than 4 passes!
What they did was to replace the original solid shafts with tubular items, telling me that "tubular shafts are stronger than solid".
Conventional wisdom here in the Uk is that a std Jag rear end is reliable for up to 450hp, after that the UJs etc need uprating. As another friend who fitted a blower to his cobra has found out.
HTH
Wilf
