Old 08-30-2024, 09:26 PM
jwshira jwshira is offline
Cobra Make, Engine: Superformance, Dart aluminum block, AFR aluminum heads.
HPD, I understand about cams being ground as you describe, but all I did was pull a balancer off and put a new one on. I would have thought that if the timing mark lined up with zero on the old balancer, it would be the same on the new one. I'm not sure how the cam grind would affect that, but if I'm missing something, please give me a bit more explanation.
