Old 09-21-2024, 10:45 AM
Chicagowil's Avatar
Chicagowil Chicagowil is offline
Default Headlight switch wiring
It has been a busy and long summer with little to no time to finish the CR1.
But finally, I have had time to get back to the final thrashing of the wiring to complete the car. I finished the front, rear and electric door popper wiring. Completed the LeMans style fuel filler connection, installed the MGB wiper motor & mounted the wheels & tires. Now I need to complete the dash wiring. I have the gauges, indicator light, heater fan switch, stereo, and wiper wired. What I have left is the headlight switch.
To those of you that have the CR1s, you, I am sure, found the wiring diagrams & instructions terrible at best.
I have the "Deluxe Dash" and I have the light switch mechanically in place. But I cannot find any wiring instructions as to which wires go to the switch. In the supplied dash harness, I have not discovered any "spare" wires without a home.
In the car harness behind the dash I do not find an indicated harness that should go to a "headlight relay".
Has anyone covered this and can you point me in the right direction?
Thanks
Thom
"Still plays in the garage"!
