The best place to start is with your camshaft. Basically the LSA should be between 112-114. Compare that with your cam. I'm sure there are many people on this forum to give you the correct grind. To get optimum results you most likely will have to change it. There is plenty of info on this forum, the web, and you tube. Do your research thoroughly. This will be a project but fun if done with patience.
Reason: adding info
