I have to back Brent here. Displacement makes power and torque, if a longer stroke for a given displacement was to make anything different, it would only go down in HP and TQ assuming a valve shrouding problem due to the smaller bore.
As far as the bike pedal comparison, yes, there is leverage with the longer pedal, but there is a fatter rider with the bigger bore.
More surface area pushing down seems to equalize the leverage advantage if there is one
It is very wild, I used to think the same thing, but as long as they both breathe the same, a given setup will make almost identical HP and TQ per CID.
I also agree that rod length has been over-hyped, a nice stable piston with a good weight for the RPM desired and enough room to not hit the counterweights...after that, just connect them.
1994 ERA Cobra, 496 Genesis FE TW (new addition to the stable)
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
