Old 10-28-2024, 02:13 PM
Pmccooey Pmccooey is offline
Default Weber 48 Ida throttle cable and bracket
I picked up a set of Weber 48 IDAs with manifold. It is the center linkage that is controlled by a lever on the DS rear carb. So I know I would need some sort of cable and bracket that makes a 90 out of the firewall to the lever on the carb. I searched around thinking it would a]be a standard set up but can’t seem to find anything? Someone must be running this setup and know what I need. I’m having trouble as usual uploading photos of my setup. Appreciate the help.
