Dropping the tank is usually the best way to do it without hacking anything up permanently.
If you really want to avoid dropping the tank, some folks create an access panel either in the trunk or under the rear seat, which can be a bit of work but at least doesn’t mess with the structural integrity. Also, check if there are any aftermarket access panel kits available for your car model some shops can install one with minimal damage.
