If your car doesn't have an access panel, dropping the tank is typically the most straightforward and clean method, even though it can be time-consuming. Cutting through the floor can work, but it’s crucial to ensure it’s done neatly and safely, avoiding damage to any wiring, structural components, or fuel lines. If you’re set on cutting the floor, are you planning to reinforce the patch afterward to maintain the car's integrity?
