Old 07-01-2002, 05:35 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
As usual, I did it the hard way, but everything fits including CR Deluxe dash accessories (sterio & instruments), and everything works.
Used Vintage air heater core, and blower, and installed in modified (very) CR box. Blower and core behind wiper motor above passenger side footwell. Air distribution box is over trans tunnel against the firewall.
Core is positioned so water lines go through firewall between passenger side valve cover, and battery. Manual water inlet valve, and cable control attach at core inlet at firewall. The way the CR manual has you run the lines out the right hand side of the foot box, I wouldn't want to be the one that has to replace those lines periodically.
No fresh air inlet, blower recirculates only. You can't button a Cobra up so tight that it needs a fresh air inlet.
I'm toasty when outside temp is 20 deg. Have shots of this if interested.
