Old 12-10-2024, 07:43 PM
jwshira jwshira is offline
Cobra Make, Engine: Superformance, Dart aluminum block, AFR aluminum heads.
Default Turn signal issues
The turn signal stalk will "latch" down for a right turn, but will not latch when pushed up for a left hand turn. After turning right, it will cancel as it should, but for a left turn, I have to hold the stalk up while turning and then just release it to cancel the blinker.
Pulled the wheel and can see the "ears", and the lug looks to be in good shape.
Any idea what's causing this? Is there a fix short of replacing the turn signal assembly?
