Old 12-11-2024, 09:28 PM
jwshira jwshira is offline
Cobra Make, Engine: Superformance, Dart aluminum block, AFR aluminum heads.
Well, I'm sure Rick sells nice stuff, but the "low quality" SPF switch has worked quite well for 13 years now, and for all I know, may still be working well, just suffering from a minor maladjustment.
Throwing a new part at every issue that arises is certainly one way to approach things, but I sort of prefer to see if I can work out whether or not a new part is truly needed before I start to R&R.
If anyone out there can provide a little more thoughtful insight regarding whether the symptoms I described indicate an adjustment issue or an actual failure of a 13 year old "low quality"part, I'd appreciate the input.
