Old 12-20-2024, 12:56 AM
likorplf likorplf is offline
If you're experiencing noise from your 9-inch rear axle, it could be caused by worn bearings or resonance from the rigid suspension. Using EP90 gear oil is standard for most 9-inch axles and should provide adequate lubrication for the bearings. Thicker oils like EP70/140 or EP140 may help reduce noise by damping vibrations, but they can increase drag and heat, potentially affecting ball bearing performance. If the noise persists after switching oils, consider checking or replacing the bearings, as worn bearings may contribute to the noise.
