Old 01-01-2025, 08:33 PM
GoFast1965 GoFast1965 is offline
Cobra Make, Engine: ERA 651 427 S/C
Based upon the limited view of the teeth on the starter gear, it looks like it may not have been properly aligned when installed and was not kicking back far enough. Are the teeth showing signs of wear further back? It looks like the ends were chewed off, which would suggest that it was only partially engaging and that is why they were torn off. It's hard to tell, because there is not a good view of the teeth further back to see if they are shiny.
@1795 I think you’re right Here are a couple of better pictures that make it look like the pinion gear was only engaging about half the way with the flywheel. Once I get the new parts, is there an easy was to adjust the engagement depth of the pinion gear?
http://www.clubcobra.com/forums/pict...ictureid=21408
http://www.clubcobra.com/forums/pict...ictureid=21407
