Old Yesterday, 06:39 AM
tortuga tortuga is offline
Default Header to Head leaks
My header gaskets keep blowing little leaks resulting in that annoying ticking...I have been using the remflex gaskets without success. This is not a quick or easy R&R and i'd like to get over to the other side of the problem. I do have solid motor mounts and doubled aft header brackets holding stock SPF headers and Gas-N side pipes.
Thinking about going the no gasket route? Any advice on what to use and how to do it would be greatly appreciated?
To do this right i am going to have to remove the while system in order to check header flange flatness (again) and get everything really clean. I have replaced gaskets in the past by just breaking the header loose and swinging the whole mess out of the way...
Thanks
Steve H
Superformance 1764
Built 427W
Aiken SC USA
