Old 01-08-2025, 01:23 PM
bobcowan's Avatar
bobcowan bobcowan is offline
If you keeping blow quality gaskets at the same place, it's not the gasket's fault. That's a weak spot for some reason, and you need to figure it out. Look for a fault in the head surface, or the header flange.
Since it's always at the top, consider that the bolts are not crushing the gaskets well. Put a washer on the header bolts and torque again.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
