Hi,
The good news is the history of this topic is in these archives. Double Venom did a piece on this subject. I ended up purchasing QA1 Lower Control Arms for a Foxbody and had them cut down to size and welded the ends back together. The result of this modification made a big improvement on the rear making it feel a lot more connected to the road and body. Because of this modification I was also able to use a 1 inch adjustable rear sway bar from QA1 as well. If you’re looking for better handling for the street this should help. If you’re looking for better handling on a track you really need to change the 4 link into a 3 link set up. Someone did this once on the forum and I am planning to attempt it this coming spring. Factory Five has a 3 link set up for a straight axle and it looks like it can be fabricated into the CR1 rear.
