Old 07-01-2002, 08:03 PM
dlowe01's Avatar
dlowe01 dlowe01 is offline
Cobra Make, Engine: RU Carcrafters / 408 Stroker
I did the same thing when I replaced the busings on mine, the first arm I melted out as you did and made a hell of a mess. The rest of them I heated up the outside with a torch and then used a air hammer to knock it out, took about 30 seconds. and a lot less mess then melting the whole thing out. Then I ended up replacing all my arms with custom ones........ I know have a set of factory arms with new urathane busings that have never been used..... Any body interested??????? I also have a set of KYB shocks for the front that I didn't use because I went with coil overs. Also have the upper and lower Mustang II with new bushings in them also, never used if anyone is interested. Hell at this rate I will have enought parts for another car before I finish this one.
