Squeeking Trailing Arms
Last year I switched out my stock trailing arms with the beefier boxed aftermarket trailing arms. I also replaced my old rubber bushings with the stiffer Polyurethane bushings.
Problem is, now everything squeeks like an old Chevy and I was wondering what everyone is using to lubricate these bushings?Also, did any of you drill and tap holes and insert greese zerts in your trailing arms? If so what kind of greese are you using?
Thanks,
Clois Harlan
"Let's roll"
"Be part of Something Good
