Old 07-03-2002, 09:23 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Yep, urethane sqeaks. I have sucessfully used silicone grease to quiet them. But reapplications are frequent to stop the sqeaks. I later replaced the bright red urethane with "polygraphite" urethane which has graphite impregnated in it to lube it, seems to work well on my chevy. The area that sqeaks the most on my trailim arms was not the circumference, but the flat faces that have washers squeezing against them. If you are lazy you can just saturate the bushings with prolong spray lube without disassembling anything, but you'll have to do this often.
