Old 07-03-2002, 11:21 AM
Whaler Whaler is offline
Default a question on those 5 point shoulder straps
Hi
I have mounted my lap belts and sub straps. 3 inch 5 pt RCI
Now I am sitting on how to mount the shoulder harnesses.
I have a round tube that is part of the upper frame behind the seats and aluminum bulkhead that runs across the car (picks up the body) I plan on using it as the attachment point
I am wondering if it's better to use 2 eyebolts 3/8" for each seat or 2 small 1 1/2"U-bolts 5/16".
Also can one use a single mount over each seat to attach two straps however centering over the seat?
I have the RCI attachment tabs which are tee shaped and would at least go thru a u-bolt where as the individual eyebolts still need some further method of attachment to the belt tab. Others like Simpson have a clasp like tee which can be clipped on and off.
Using the ubolts the attachment would not lie as flatly or as nice as eyebolts have the benefit of rotation to accomodate the tee tabs. The ubolys would house the tabs in a cocked like position as they would be mounted on the horizontal.
I am sitting on this until I am sure how to go about it and not drilling any bloody holes until then......Thanks
Tim
