Old 07-05-2002, 08:35 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Petek,
You're right on all the way around. Sounds like you used the stock CR's older suspension set up. Did you cut a coil from the front springs?
Tommy's uses Carerra's and they work great, don't know if Don has them or not. 13x250's are really the way to go for street and a little drag/ato cross use. I've used 300's, does stiffen it up a bit, but an old guy with crushed discs really like the 250's.
(We use "Blue Coils").
DV
