Old 07-06-2002, 07:51 AM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
OhBouy: What fuel sender do you have. If it is a VDO unit I can fax you the instruction sheets. Typically the length of the float arm varies with the depth of the tank and the length of the sender unit. After you set the unit to the correct length you cut off the excess and make sure the float arm is in the right direction or your gage will show empty when full and visaversa.
Jim
OhioCobraClub.com
