Old 07-06-2002, 11:44 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Chopper is dead on the money
Likely your heads are warped/loose/cracked. Check torque specs and procedure first, if it's loose, that is likely your problem. IF they are loose, then: Do not run it much at all, before you drain the new oil and check for more antifreeze!
If they are correctly torqued, it's warped (more likely with aluminum heads) or cracked (more likely with cast iron) heads.
It could also be a cracked block !
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
