Old 07-07-2002, 08:46 PM
Hi Cal Dave S. runs 58 webers and is running alot bigger cam than 225 duration at 50 lift . He will not say what is in it but it is bigger than 650lift, 235 duration at 50 lift and the car turn 7000 rpm. It runs low 10.20' in the heat of the day, and short shifts too. It idles at 900 rpm with no problems. Kuntz builds some 680 lift 238 duration with a set in 48 ida's His red line is 6800 rpm. The carbs run out of flow. Hey Bernie Did you have your cam degreed and checked befor it was installed. Check the cam card for the centerline and that it was set right Good Luck Rick Lake
