I'd say the most likely cause is a "simple" head gasket failure. Did you re-torque the head bolts after the engine was run for a couple of hours? Most of the aluminum head manufacturers will recommend a re-torqueing. This could contribute to the gaskets failing if you didn't.
h dog
