Thread: Engine Help
Old 07-08-2002, 03:54 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Check your valve adjustements, it sounds like the exhaust valves are not closing all the way. Setting valves dry is trickey. Pull out sparkplug, put finger over hole, crank motor, if it doesn't PUFF loudly, than lack of compression, check valve adjustements.
