Old 07-08-2002, 04:35 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
It has a hint of fuel smell? That means there is probubly gas in your oil, change it. If you have lots of air coming out the breathers than you have excessive blowby past your rings. Do a leakdown test to verify. Check your carb float levels to see why your oil smells like gas, one float could be stuck.
