Old 07-09-2002, 12:33 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Andy:
Sounds almost good to me, but how much is "almost" closed? How does this sound to everybody: Mark your harmonic balancer every 90 degrees (you can buy adhesive tape that is specially marked for harmonic balancers). This way you can tell when any given piston is at TDC. Adjust both intake and exhast one cylinder at a time with each one at TDC on the compression stroke (both valves closed).
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
