Old 07-09-2002, 05:32 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Hotfingrs:
But what is almost closed? Does not sound very scientific. I wold like to do it to an exact "spot" every time. BTW I just replaced a couple of valve seals using compressed air like you said. I had the car in gear without the e-brake on and boy did I get a suprise when the car rolled forward about a foot because the air pushed the piston to the bottom of the stroke. Thank God it went forward, I had the rear end right against the door.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
