linkage adjustment.... I had a linkage problem and I called David about it here"s how to adjust on the shifter body you will see a hole approx 1/4 " insert a drill bit or an allen wrench all the way through it will fit into a notch on the other side of the body be sure to use the tightest fitting bit in the hole!! take the control arms loose at the thread end, and be VERY EXACT 1 TURN OFF IS BAD whe I did this it made a world of differance.... good luck
brizz
