If this is truly a lowrise engine you should know that the edelbrock heads are based on the medium riser design with wider shorter ports than the lowriser. If you have compression issues you may want to go with the small chambered edelbrock heads to bump up compression the shelby heads are big chambers even bigger than the big edelbrock chambers.
They serve also who stand and wait
